PAINTING:
Ok, out on the paint table, while useing an Airbrush 9 times out of 10 will give you a better paint job, I kinda wanted to see what I could do with this model just useing sparay cans. Our base coat was simple grey primer and the crescent stripes are standard flat black - both out of inexpensive spray paint cans I bought at the local Dollar Store. One trick you can do - after shaking the cans up good to mix the paint, let them soak in warm water for about an hour before you paint. This will help the paint flow out of the can more smoothly and you won't get those "blobs" of paint that a spray can sometimes spits out.
Hold the can about 2 feet from the model and spray using a back and forth motion till the area you are painting is covered. Don't just aim it straight at the model and start spraying. This has your can spraying at full speed before you pass over the model.
This is a close-up of one of the wings of the Raider right after painting. You can see the edges of the tape and how the area to be painted was only just painted enough to cover it.
Here is a pic of the Raider with the paper and masking taken off after painting showing the crescents and how sharp their edges came out. Just like the decals.
NOTE: I did make one STUPID mistake. :frak: :frak: :frak: The tape pulled up one of the decals when I went to take it off after painting.
I have spares to replace them with but someone out there with only one set of decals would be screwed big time. Word to the wise - wait till all the painting is done before putting the decals on.
Next time we will do some final weathering, detailing and putting the Dullcoat on.
