NEW CYLON ARMOR AVAILABLE
Re: NEW CYLON ARMOR AVAILABLE
Post by FLIGHTLDR SERPENTINE » Tue Jan 17, 2017 9:31 pm
I got the helmet kit today. It looks like a good kit. Parts are clean. :loveit:
Post by Red Eye » Wed Jan 18, 2017 11:06 am
Are you going to make it a gold / copper Command Centurion or a standard silver chromed Centurion version?
trooper18938
Post by trooper18938 » Wed Jan 18, 2017 11:47 am
still waiting on my helmet kit.
Post by FLIGHTLDR SERPENTINE » Wed Jan 18, 2017 5:27 pm
After I assemble it, I am going to compare it to my other helmet awaiting plating to see which one I like better. That one will be the copper one, and will get my metal mouth grill. The other I will likely just chrome. I really like that it is ABS. I wish I had my suit in ABS instead of styrene.
actias
Post by actias » Wed Jan 18, 2017 8:24 pm
ABS is what the original studio units were made out of. I will have the entire set of armor that goes with the helmet, in ABS, soon! Here's some pics of other parts. Also these are ABS - snow white gloss like the ABS stormtrooper helmets. They have CLEAR lines where to trim. Parts are clean!
actias
Post by actias » Wed Jan 18, 2017 9:01 pm
For comparison of my ABS to the CORA unit on the left.
Post by GoldCylon » Wed Jan 18, 2017 9:21 pm
Both of those helmets are nicely done, and I do see slightly different detaining difference in the trim details. Knowing the composite differences one ABS, and the other Styrene does make it easier on what one to chose. Rookie level builders clearly you are not should select the Styrene, and then more advanced builders the ABS is the right choice. :cylongold:
actias
Post by actias » Wed Jan 18, 2017 9:26 pm
That's true. It's just a matter of choice.
Post by GoldCylon » Wed Jan 18, 2017 9:53 pm
More of a matter of skill. :cylongold:
trooper18938
Post by trooper18938 » Wed Jan 25, 2017 12:27 pm
just received the kit. really great, there are cutlines in the pull, extra abs, templates, and sharp detail pieces. as a size parameter....my CORA kit fits inside this one. they both have different detail and eye pieces, and will make a nice pair. gonna build them next month and try chroming, possibly a good place in CT, or the spray,, and some lights, then pictures...
actias
Post by actias » Wed Jan 25, 2017 8:35 pm
I'm glad you are happy with it! Here are some step by step general guidelines to help you guys build your kits. I hope it's helpful.
1) TAKE YOUR TIME! It's not a race.
2) Measure TWICE and cut ONCE.
Heed that advice and you will be happy with your build or any build for that matter. Have fun with it. :cylon:
darthhair
Post by darthhair » Fri Aug 11, 2017 6:04 pm
Thought you guys would like to see this helmet finished. This was displayed at the Smooth On booth at Celebration Orlando as well as Denver Comic Con.
https://www.facebook.com/DHPFX/videos/1283625765085348/
Post by GoldCylon » Fri Aug 11, 2017 6:57 pm
Looks great
actias
Post by actias » Tue Sep 05, 2017 8:51 pm
Dale
Post by GoldCylon » Tue Sep 05, 2017 9:23 pm
Those measurements are not defined from suit to suit. They all vary a bit since it was free hand that marked them to cut to fit. So lets say on my 1 the measurement of 1 is 3, and 1/16 of an inch. The second pack might be 2/16th inch more then mine, and a 3rd one might be 1/16th of inch less. I would do what is the best look, feel, and easy of building the back pack. I will say if this is your first one it is a bit of a challenge to assemble I would suggest you try 2 inch wide blue painters tape to help make the adjustments, and spot hold it together. There is no wrong if it fits, and looks good.
