Eye Scanner
ACK! You spilled the beans, now the world knows how to blind us Cylons. lolChrisPappas wrote:For the light to be on, you have to pull out the
BTW, as a note, the Cylon eyes did not have an off switch. If you wanted them off, you disconnected it from the belt.
So, when a Cylon's eye would "stop" scanning - and stay lit - as they "died" ... how did they do that? Did they have a totally different scanner circult/set up in a prop helmet for close ups only (no actor inside)?
Tricky TV shows! Knight Rider was like that - had a special - close up shots K.I.T.T. dash, and the "driving car/stunt cars" had different set ups.
Re: Eye Scanner
I have been asked to post my 3 cents worth..
The neon lamp will only work if 110 volts is applied to the belt, such as plugged it in the wall to recharge the battery.
Often the neon lamp is used as a current limiter for the recharge circuit. I spoke a a friend that used to run the old camera for a TV studio, He says that the old cams used 24 volts DC to run. I suspect that the cam belt is a dual voltage unit providing 12 volt and 24 volts DC. The eye scanner probably used 12 volts to run.
I think the cell rating was 1.25 volt each, and that there was 20 cells in the belt, providing 25 volts DC MAX. But given inefficiencies probably 23-24 volts.
Unless someone can find specification on the actual cell used in the belt, this is what I feel could be right.
Re: Eye Scanner
14 cells, 1.2 volts each, wired to provide either 16.8 or 8.4 volts or both.
The eye ran on split voltage, 16.8 to the lamps, 8.4 to the circuit. The circuit had an on board voltage regulator.
Chris
Chris
- Skullbeast
- Outpost Commander
- FLIGHTLDR SERPENTINE
Re: Eye Scanner
Yea, interesting read. Maybe I should just pull my original eye scanner out of my helmet to use in my command centurion? Naaa.
Re: Eye Scanner
But a few detail photos of the unit itself would be nice and great to see for all of us.
Can it be done?
Can it be done?
Re: Eye Scanner
I thought I posted a few already? Let me check and see.
Re: Eye Scanner
Yeah, I totally forgot about that, sorry!
They're located here:
http://www.byyourcommand.net/cylongalle ... 291&page=2
Re: Eye Scanner
Too late! I tore mine apart again just for you, Red Eye.
This time with much more detailed images… posted HERE: viewtopic.php?f=7&t=3064&p=32190#p32190
