Groupleader Zeta's current project
Post by groupleaderzeta » Wed Jul 22, 2015 3:19 pm
I am currently reworking my classic battlestar galactica cylon costume. I am repairing parts and upgrading the eye to my version 4 kit. I am also adding a on the fly voice changer.
reference pic from 2011
Structural repairs to the helmet are done. Just need to retouch up paint, Install new eye scanner.
I am also making a correct undersuit. This pic is of the undersuit for the silver cylon centurion, the gold centurion has a all black undersuit.
I revamped the belt for the install of the on the fly voice changer. on the original, the belt provided the power to run the eye. Because I have updated the eye to use modern electronics, the power can be in the helmet, the belt now contains exciter speakers for the voice.
The exciter speaker does not have a cone like a normal speaker, instead it is only the driver and uses the flat surface it is attached to to replace the cone. In this case the plastic cover is used as the speaker. Here is a audio test using a Mp3 player as audio source and going through a 10 watt amp.
The voice changer is built around a electro harmonix iron lung vocoder. This is a pic of a early experimental setup. The voice amp will be replaced by the belt. The Mp3 player will be replaced by a electronic ciruit board. The mic in the helmet will be wireless.
Re: Groupleader Zeta's current project
Post by Cylon-Knight » Wed Jul 22, 2015 7:44 pm
Well done Centurion!
Eternal order and perfection is the goal of the Cylon Empire - great work on your updates :)
Post by rustycylon » Thu Jul 23, 2015 1:28 am
what paint did you use for your gold cylon?
Post by groupleaderzeta » Thu Jul 23, 2015 11:45 am
rustycylon wrote:what paint did you use for your gold cylon?
Rust-Oleum metallic Gold spray paint, #1910830. Then did a clear coat of rust-oleum. I then did a black wash with rust-oleum flat black, using acetone and paper towl.
Post by rustycylon » Thu Jul 23, 2015 2:35 pm
thanks for the quick reply
Post by Red Eye » Fri Jul 24, 2015 5:38 am
Can't wait to see your updated Command Centurion WITH voice...
Post by GoldCylon » Sat Aug 08, 2015 5:00 pm
As normal you do great work. Thanks for sharing. :cylongold:
Post by FLIGHTLDR SERPENTINE » Sun Aug 09, 2015 1:11 pm
Inspiring. Any new pics? :cylongold:
Post by FLIGHTLDR SERPENTINE » Sun Aug 09, 2015 1:12 pm
I'm very interested in your undersuit. Who's doing it?
Post by groupleaderzeta » Sun Aug 09, 2015 1:37 pm
FLIGHTLDR SERPENTINE wrote:I'm very interested in your undersuit. Who's doing it?
I am going to try making it.
Post by FLIGHTLDR SERPENTINE » Sun Aug 09, 2015 6:42 pm
I'm also doing a command centurion, and I am a bit of a big boy. Very interested in your progress.
