Cylon helmet upgrades
welshchris77
Post by welshchris77 » Fri Jul 27, 2018 7:42 am
I have been upgrading my helmet the last few days.
After trooping in it a few times I found the Kropserkel foam liner wasn't very comfortable and just didn't fit that well so I stripped it out and replaced with a hard hat liner.
I tested out the liner by duct tapping it in then marking it out with a pencil and glueing it with E6000.
Sent from my SM-A310F using Tapatalk
Chris Lewis
welshchris77
Re: Cylon helmet upgrades
Post by welshchris77 » Fri Jul 27, 2018 7:51 am
Microphone superglued to a piece of abs and Velcro added.
Usually I don't use the 'stick on Velcro' as it often fails over time, I use the 'sew on Velcro', key up the surface it is going onto with some heavy grit sandpaper and use superglue and activator (being careful not to glue my fingers to itImage)
Chris Lewis
welshchris77
Post by welshchris77 » Fri Jul 27, 2018 7:57 am
Small strips of double sided Velcro superglued to the inner rim, these can be used to roll up the cable and keep it tidy and out of the way.
I did have a 3mm female jack on the end of my mic cable but it was crackling alot so I replaced it with a Phono jack, doesn't pull apart as easy and zero cracklingImage
Chris Lewis
welshchris77
Post by welshchris77 » Fri Jul 27, 2018 8:13 am
Next up is cooling fans, i used two 5v blower fans connected to a battery pack containing x3 1.5v AA batteries.
I used jst connectors on all connections for servicing.
The fans are attached with Velcro which allows me to reposition them as needed.
At the moment I have them pointed the same direction to create good airflow around the helmet, these fans can really blow!Image
I added connectors to the Kropserkel battery pack, moved it back more, removed the sticky back Velcro from the battery unit lid and attached new Velcro to the back of the battery unit, I also removed the switch and relocated it next to the fan switch so it is easier to access.
I fabricated a switch structure from plasticard to accommodate both micro switches.
All done!
Chris Lewis
Post by Cylon-Knight » Fri Jul 27, 2018 2:24 pm
BRILLIANT!
I need some fans and the power supply. Love it. Could you share where you got yours?
...I don't have any padding in my helmet... I guess I have a big head!? :shock: :roll:
:frack:
Soda Can
Post by Soda Can » Sat Jul 28, 2018 4:54 am
:loveit: very nicely done.
I might have to try something similar once I get my act together.
welshchris77
Post by welshchris77 » Sat Jul 28, 2018 6:48 am
BRILLIANT!
:frack:
No problem!
Fans
https://www.ebay.ie/itm/1pcs-5015S-5V-0 ... SwCi1Z4Gj5
Power pack (I salvaged mine from a dollar store (euro store) torch)
https://www.ebay.ie/itm/1-2-3-4-6-8-x-A ... 0064481003
Micro switches
https://www.ebay.ie/itm/20pcs-lot-SS12F ... Swf-xZnsC6
I used 22awg wire
you will also need heat shrink tubing and JST XH connectors (optional)
https://www.ebay.ie/itm/50SETS-of-JST-X ... GK2XOKQVvw
https://www.ebay.ie/itm/Mini-Mirco-JST- ... SwevlaJ6h3
Chris Lewis
Post by FLIGHTLDR SERPENTINE » Tue Sep 11, 2018 10:47 pm
wow. Cool.
