As you will see in the next couple of photos, in the end I actually did this in sections. The chrome wrap is just too thick to be able to get a good sharp "round the corner" look. As you can see on the picture looking In the backpack above, at the bottom you'll see some wrinkles in the film.
The corners were just too tight.
So, to make the film thinner, it's actually 3 layers...
1st being the sticky cover
2nd being the actual film itself
3rd being a clear protective film... Take this OFF BEFORE you start heating and wrapping.
From 2-3 feet away and further, you don't notice the Chrome TAPE which I also used to cover/join each section together.
As I said this was only a temporary job, but the overall results managed to get me through an event I wore it for and no one commented. I'm also using it for Londons Comicon next weekend, then I will finally take it to be chromed. If anyone would have commented, I would have just mentioned that the original creator (Andrew Probert) used what ever he could to repair the parts...
www.DarthMojo/Wordpress.com/2008/09/17/ ... n-history/
He states that as pieces were damaged during filming, sections were replaced from other damaged parts that were otherwise too knackered to use, thus using what ever method he could to blend in. You never notice on the actual footage the joins.
On the back of the back pack, it's just too bumpy where the black pipes are, so I took the pipes off, and just sprayed it using a good chrome spray. you'll notice a bit of a sheen difference between the film and the spray, but as long as you cut the film as neat as possible on the edge where it blends in the recess, you should get away with it (I think I did to an extent)
As a final word, This costume was approved by the 501st.
Mack
