The two kits, side by side. You can see how the new one has a much taller box.
Left: 2007 top. Right: 1978. Identical except for the addition of two flares on the engines.
The bottom halves. They are the same except for the copyright notices.
Left: 2007 stand still in the plastic. Right the parts for the 1978 stand.
Left: 2007 engine vent. Right 1978 engine vents and other parts.
Left: 2007 parts. Right: 1978 parts. I am missing three parts from my 1978 kit. 1. A square engine block. 2. A rubber band. 3. A tiny little block with a notch in it (an internal piece to the missile launcher mechanism).
Left: Other side of the above 2007 parts. Right: Photo of the two missile ends that my 1978 kit had glued in when I bought it.
Left: More 2007 parts (Right is just a spacer that looks cool and keeps the photo essay "balanced"
All new engine parts for 2007.
All new clear engine parts, to allow for internal lighting (the kit has no other parts or instructions than just "clear parts suitable for lighting."
Left: 2007 instruction booklet. Two sheets folded and inserted inside each other to form a book (no staples holding them together). Right: 1978 instructions. One big sheet that unfolds. Also, the 1978 decals.
2007 decals - came inside of the instruction book for protection. They also have this blue/green cover sheet.
2007 decals with the cover off.
2007 decals close up.
Close up of the new flares on the top half of the 2007 kit. They are for more support to the vents, and to close them off I'm guessing.
Left: 2007 with the vents in place so you can see what the new flare does. Right: Same setup with the 1978 parts. At first glance I thought, they looked better without the extra flare.
Left: 2007. Right: 1978 - second glance shows that maybe the new flare is a good thing. The inside of the vents have "junk" that takes away from the look.
Left: Close up of the 1978 copyright on the outside of the 2007 kit (That's no typo). The 1978 has no text on the outside - only the inside. Right: The two kits again, I'd better get to work on them, huh?
So, side-by-side... the two remain nearly identical.
1978 - had working missiles!
2007 - everything 1978 had - but has deleted missiles. Added much more detailed engine parts, clear parts for lighting, decals that better match screen used Raider markings (even has decals for black lines on the underside). Probably my favorite new parts are the "structure strips" - the bars with circles cut out of them next to the main laser cannons. A small item, but really helps the kit's overall final look.
