Upgrades for the next gen of Zeta eye scanner
Post by groupleaderzeta » Sat Nov 19, 2011 9:16 am
Hello everyone,
I am conducting research for the next generation of the Zeta cylon eye scanner.
Please post your opinions to the following questions.
1. Should I keep sound on eye scanner control board?
2. Should I keep the control board mount in the mohawk or place behind the mouth grill as in screen used?
http://www.byyourcommand.net/cylongalle ... ics_01.jpg
http://www.byyourcommand.net/cylongalle ... ics_02.jpg
http://www.byyourcommand.net/cylongalle ... ics_03.jpg
3. Continue with using LEDs or use bulbs?
Thanks,
Zeta
Post by Skullbeast » Sat Nov 19, 2011 9:43 am
3 or 4 chasers
Die human!!!
Re: Upgrades for the next gen of Zeta eye scanner
Post by groupleaderzeta » Sat Nov 19, 2011 9:56 am
hey skullbeast,
Do you mean different scanner programs??
Post by Skullbeast » Sat Nov 19, 2011 10:34 am
No but the length of chase. 3mm is best to. Closer to the grain o'wheat bulb.
Die human!!!
Post by Red Eye » Sat Nov 19, 2011 11:29 am
Bulbs would be great, indeed! :cylon:
Post by Jenne » Sat Nov 19, 2011 12:41 pm
I prefer the board in the mohawk, because your mouth is behind the grill, and if you breathe out maybe some moistue will come over the board.
Post by Cylon-Knight » Sat Nov 19, 2011 1:06 pm
1. Only if the sound can be my own (larger sized, but not massive) MP3 file. Would need a way to load it in, or have it be the stock sound ;) HA
2. I too prefer the mohawk. Or outside of the helmet if need be. There isn't much room in the mouth area/that would add more heat in your face too... I'll pass on a mouth board.
3. LEDs.
Bulbs are 1:1, yes. However, they are MUCH dimmer, have shorter life span, run hot, and need more power. Better (in my mind) for a display, not a working costume helmet. BUT - offering a blub scanner for the 1:1 pure is a GOOD idea!
Those are my ideas. :)
Post by GoldCylon » Sat Nov 19, 2011 10:28 pm
A little insight that might help. When the lights are not up against the edge 5 bulbs are lit up. The center being the brightest, and the closest to center about 1/2 way lit up, and about 1/4 power on the outer lit bulbs.
Post by groupleaderzeta » Sun Nov 20, 2011 7:49 am
Hmm..
Anyone have a schematic of a screen used circuit or even a closeup pic of a screen used board, so I can read the numbers on the chips???
I have no Idea how they did that with analog chips. Not sure if they had digital chips back then available.
Post by GoldCylon » Sun Nov 20, 2011 12:22 pm
It is a wire bread board type of build. No matter work at all to it, and just wire wrap running from point to point. 100% experimental looking more than a real work working model, but it is what they used. The link below is some of the chips used. There are 5 of these chip, and 4 of the 5 are in charge of lighting 4 of the bulbs.
http://www.ebay.com/itm/390334437691?ss ... 500wt_1325
