*Official* Eye Scanner Thread
The Cylon Empire
Order and Perfection
Post by The Cylon Empire » Wed Mar 23, 2011 10:05 pm
The 1978 Cylon Centurion has a custom built electronic eye.
Screen accurate details:
  • 32 light bulbs
  • Electronics drive 32 bulbs in a repeating left to right sweeping
  • Powered by the G&M Battery belt
Low cost alternatives:
  • The modern day replacement for the classic bulb scanner is a 28 to 32 LEDs eye. Typically powered by 9 volt battery in the helmet or under suit. Several ByYourCommand.net members produce varying levels of eye for various budgets, all well built by members in good standing with the Cylon Empire. Some include sound options as well. Members: See the Cylon Store for details.
  • MP3 players with mini speakers are typically installed in Centurion builds to add the eye warble sound effect to a finished costume for a polished and professional level of Cylon-ness. The players can be installed in the helmet, chest armor, back pack, etc. It is the builder's decision as to what works best for their build and budget.
Notes:
  • No sound effects in original 1978 Cylon Centurions, that was added in post production to the show's soundtrack
(photos to follow)
This is an *official* thread of the Cylon Empire **********************************
This first post will be edited when needed to add or correct information.
This thread is open to discussion below, BUT NOTE, the thread is subject
to heavy pruning to keep miscellaneous chatter down and the topic focused.
Centurion, you were created to serve our empire.
You exist that the Cylon Empire my grow and organize the universe.
Eternal perfection and order is the goal of the Cylon Empire.
Re: *Official* Eye Scanner Thread
Post by FLIGHTLDR SERPENTINE » Tue Aug 30, 2011 6:58 pm
What was the original voltage that the eye ran off of? I'm currently using a 6v. battery to run my 'screen-used' helmet and it works, but is kinda dim.
Post by GoldCylon » Tue Aug 30, 2011 7:33 pm
I think I have two 12volt power adapters (laptop) units running my scanner.
Post by FLIGHTLDR SERPENTINE » Tue Aug 30, 2011 11:02 pm
so 24v?
Post by Big Al » Tue Aug 30, 2011 11:39 pm
The belt that originaly powered the eye was a cam bat belt and I think it had several diff voltages to pick from depending on if you were using a cam or a spot light or???
I may be wrong ......Dale would know
Post by Cylon-Knight » Wed Aug 31, 2011 10:49 am
More info on the belt is in the Belt thread:
viewtopic.php?f=7&t=1303&p=14995#p14995
Belt info based on this image:
http://byyourcommand.net/cylongallery/m ... temId=2918
Post by FLIGHTLDR SERPENTINE » Wed Aug 31, 2011 11:06 am
110 v... so if I 'plug' my scanner into the wall it wouldn't burn up? Hmm... Maybe I'll be cautious and try 12v next...
Post by Cylon-Knight » Wed Aug 31, 2011 11:09 am
FLIGHTLDR SERPENTINE wrote:110 v... so if I 'plug' my scanner into the wall it wouldn't burn up? Hmm... Maybe I'll be cautious and try 12v next...
I dunno. All I have is that photo. *sorries*
Whoever has a real 1978 scanner will have to let us know.... ;)
Take it to an electrician - have them pick it apart for posterity.
Post by GoldCylon » Wed Aug 31, 2011 11:10 am
No the belt doesn't power out 120 AC volts. That is a built in charger. There is a switch to select 12 volt or 6 volt.
Post by FLIGHTLDR SERPENTINE » Wed Aug 31, 2011 6:19 pm
Ok, makes more sense... thanks Dale. :salute: :cylongold:
