ByYourCommand.net wallapaper - #14
Official Wallpapers for the best forum in the universe. Download and set them to your computer desktop wallpaper and stare at them all day and night - what could be more fun?! BY YOUR COMMAND
Post by Cylon-Knight » Mon Sep 05, 2011 1:28 am
Wheeee Wallpaper #14
Re: ByYourCommand.net wallapaper - #14
Post by FLIGHTLDR SERPENTINE » Mon Sep 05, 2011 1:49 am
love it! :cylon: :cylongold: :cylon:
Post by Red Eye » Mon Sep 05, 2011 10:17 am
:loveit: PERFECT as usual! :loveit:
Post by Big Al » Wed Sep 07, 2011 9:28 pm
[quote="Cylon-Knight"]Wheeee Wallpaper #14
Post by Cylon-Knight » Thu Sep 08, 2011 9:06 am
Answer: Could be a couple of them :shock:
There isn't a "15 inch screen" size... what your screen shows will be based on the resolution you are running (and you could change it to a few sizes if you wanted).
You'll need to check your resolution. I don't know what OS you are using but am guessing it is some form of Windows - so try this:
-Right click on your current desktop wallpaper.
-Select "Properties" from the fly out menu (typically at/near the bottom)
-Look for a "Settings" tab
-You should see a screen resolution area that has a slider (to change the resolution) and a display of your current resolution. THAT is the "size" wallpaper that would be best to use.
Optionally you could pick any and stretch or squish it to fit, but it might look odd/loose some image/not have enough. I have each size set to show the image the best.
Hope this helps, sorry long post... COMPUTERS! Whattcha gonna do?! Can't live with or without em. :)
Post by Big Al » Thu Sep 08, 2011 9:25 am
:cylon: Thanks CK....Yea it's a 15" Dell Inspiron with Windows 7 Home Premium.
My Screen res is 1366 x 768
Perfect answer! once again! :salute:
the one you made for Sean is perfect! the res was the answer.
Your pretty good at this! :salute: :salute:
When I change a pic size I only reduce and I like to do it Proportional so not to distort the image.
Thanks again ...(I have a cool new desk top!
Post by Cylon-Knight » Thu Sep 08, 2011 11:53 am
Enjoy!
Return to “ByYourCommand.net Wallpapers”
