Care for latex masks
- Skullbeast
- Outpost Commander
Cleaned only with mild detergent and water (dish soap thinned on a towl).
Keep out of sunlight keep out of sunlight keep out of sunlight. Direct sunlight will destroy it no time. You can prance around in the sunlight just don't stay out there for days on end. Keep about 70
Re: Care for latex masks
But one should not clean cracks with a brush while you prance around in the sunlight.
Great tips Skullbeast! Thanks for all the professional info you pass along. You ARE a Cylon Empire V.I.P.
Second that! *Bows down*
And I was just about ready to take my mask to the local Cylon body wash. OK this method given sounds much easier, and cheaper.
- Cy
- Raider Commander
And NEVER clean your crack in public.Cylon-Knight wrote:But one should not clean cracks with a brush while you prance around in the sunlight.![]()
- Big Al
- Command Centurion
Cy wrote:And NEVER clean your crack in public.Cylon-Knight wrote:But one should not clean cracks with a brush while you prance around in the sunlight.![]()
- Big Al
- Command Centurion
Skullbeast; Is the Latex you use today for your masks any better or more durable/ resistant to deterioration elements like (UV/ Air polutents) compared to the materials that they used in the 70's ?
- Skullbeast
- Outpost Commander
Not so much it's natural so it rots. But proper care and they last a long time. Tom Savini has some real old ones 30 plus they are fragile but intact.
