Thought I would drop by and let you see the new thing I stuck myself with.
Ready for a ride? The 1st make of this,,needed remade with some of the things I have compiled
in a few remote brain cells.
https://www.youtube.com/watch?v=MN0yGsfNhOs
This should be a romp n ride!
Did it to myself again.
I was just thinking of something to work on. So, I started messing with the TOS Raider Thrusters.
Then the Cockpit some. And I just watched my video The Chase-Ressurrect, and thought this is good, it just
needs refined,redone.
I was thinking that this should be relatively quik,simple re-opening old scenes and updating everything.
I also re- did the Lasers of the Raider. (no pics yet) And created a scene set up for Particle Pdeflector-
--Is not yet correct, but I can now make the laser bolts explode on impact... ----
Hopefully I can figure it out enough to make it work and look good...
Regards,
Randal R.
BSG Series- The Chase-Ressurrect (remake) (wip)
- Thunderstruck
- Raider Gunner
- goldcylon1
Re: BSG Series- The Chase-Ressurrect (remake) (wip)
Thunderstruck wrote:Thought I would drop by and let you see the new thing I stuck myself with.
Regards,
Randal R.
pretty Slick
- Thunderstruck
- Raider Gunner
Well, I Thought of You Jar Head Tin Cans. And am showing you an update.
This is only on this and 1 other thread, so none other than Here and Scifi Meshes has seen it.
May be on my guild Star Wars, but that may be 15 people will se it..
This is Gettin Good.!
http://youtu.be/hp69zZQD2hk
Don't Forget to see the video^^^^
Info:
Fixed one clip with too much Motion Blur. R13 is a bitch.Either on or off..no detailing blur ( with effect).based on Cam-movement. Added some new clips.Reshot the Double/Triple Explosion shot of 2 raiders.Last clip am thinking of finish the shot with rdr blowing up with a Viper swooping in from Cam angle.
But I do believe I have on a few occasions gotten those Damn Motion Blur Tags to actually work with Standard Renderer, but it had to have been accidental or a good glitch for a change ,,
Will Probably have to Reshoot the last clip witout te blah (without the blur)
Thanks you for Revisiting.
Regards,
Randal R.
Info:
Regards,
Randal R.
- Thunderstruck
- Raider Gunner
Close toa Final Video HERE!
UPdate- Mostly finished. But am seriously thinking of extending this with
the second Audio Track.
On Vimeo HERE!
https://vimeo.com/102472645
Thanks for Revisiting.
On Vimeo HERE!
