Yes, there was a CG model of an SR-71 Blackbird in the Ragtag Fleet. It is one of many "Easter Egg" ships that were placed in the deep background that was never meant to really be seen.
Blackbird Class Transport
Re: Blackbird Class Transport
I haven't heard that story before. I take it that this insert if from the 2003 series?
Yep - IIRC, Lee Stringer added this, the Enterprise, Sulaco, Nostromo, Firefly and a bunch of other out-of-universe models to fill in the spaces of the RTF to make it look more massive. I suspect he had all these CG models lying around on his hard drive and it was easy enough to do a copy-paste job on the final composite. None of these things were ever supposed to be seen clearly, and high-def TV's were only really just getting started around this time and still very expensive. In later interviews with Stringer, Hutzel and Drexler, a few secrets were let loose over the years.
Here is a high-res pic that Stringer put together back in 2004, with many of the ships mentioned. The SR-71 is way off in the distance, in a cluster of three ships directly below and to the left of the Celestra. And here's a lower-res, yet still visible, cap of the Enterprise in formation:
I was aware of most of the ships inserted expect the SR-71. Thanks for pointing it out.
Side note the 2003 miniseries was filmed in standard def, but the TV series was filmed in HD.
Is it the Blackbird...
or should you "Behold, the eternal glory of Jetfire!"
(Transformers: Revenge of the Fallen (2009))
heehee
heehee
And don't let's forget Snoop from the GoBots...
