Using a Arduino nano, mp3 player, amplifier chip, 1w LED's and drivers for the circuit run off a 7.4v camera battery.
Prototyped the circuit on breadboards and have the code working.
Have since increased the LED's to x6 blue for the barrel (one for each slot) with a white LED for the muzzle.
When the trigger is pressed the LED's will flash blue in sequence along the barrel ending in a white flash at the muzzle and Cylon rifle sound!
Rather than wrapping the acrylic tube in electrical tape I decided to go for a more 'sanitized look' so I went about making a barrel shroud that would emulate the 'look' of the original but also be easier to remove for maintenance if need be.
To fabricate this piece I cut up a black storage container, heated it and shaped it around a piece of pipe then then cut slots. I glued some Velcro to hold it onto the main body of the rifle using E6000.
The LED's will fit inside a smaller acrylic tube, I bored a hole using a spade bit in the cast resin muzzle piece to accept the tube then fabricated two clear acrylic washers to keep both tubes in place
Using jst connectors for the LED sub assembly for future servicing.
I trimmed the clips on the connectors to make them slightly easier to separate.
These are great little plugs!
Internal support structure for the stock made from plasticard with supports for the battery.
The stock can slide out of the main body to access the battery
Battery contacts made from copper wire, contact ends flattened out with a hammer and holes drilled to allow for soldering.
Wires soldered, heat shrunk and jst connector added
