Cylon Hyperdyne labs scanner with diffusion
C.O.R.A
Post by C.O.R.A » Mon Jun 01, 2009 11:38 am
I took the Hyperdyne Labs scanner and my led holder but this time I pulled the led back a little and added two layers of defusion paper and then a piece of red gel. It now more looks like a bulb scanner. Here is a youtube clip of it in action.
http://www.youtube.com/watch?v=DXBNa2GvmT4
http://www.hyperdynelabs.com/products_e ... oLight.php
Jim
Post by GoldCylon » Mon Jun 01, 2009 4:03 pm
That has a real good look to it that is a much cheaper alternative than going the route of a real bulb that runs so much more money. Great idea to do that. Now how does it look in a helmet in the day light from 20-30 feet away?
Post by Cylon-Knight » Mon Jun 01, 2009 6:05 pm
It still all fits inside of a helmet?
C.O.R.A
Post by C.O.R.A » Wed Jun 03, 2009 12:32 pm
http://www.youtube.com/watch?v=gvsoiQcF ... annel_page
Here it is in day light a few feet back.
Jim
Post by Cylon-Knight » Thu Jun 04, 2009 12:31 am
Perfect.
GREAT WORK!
Post by Red Eye » Thu Jun 04, 2009 10:53 am
I wish I had a scanner like that...
Thanks for sharing it with us!
Mr Fett
Post by Mr Fett » Tue Jun 23, 2009 11:01 pm
That looks amazing. What's defusion paper? I assumed the red gel was like that used for concert lighting rigs.
Post by GoldCylon » Tue Jun 23, 2009 11:51 pm
Mr Fett wrote:That looks amazing. What's defusion paper? I assumed the red gel was like that used for concert lighting rigs.
You need to use a clouded sheet of white plastic, and then a red sheet of plastic. That will give you the haze you need to give the correct blur that the real ones have/had.
Post by Cylon-Knight » Wed Jun 24, 2009 12:44 am
So, GoldCylon, how much room should one expect in the helmet with the eye electronics in place? I know you can still wear it, but wow, it is pretty much right up in your face, huh?
I am going to craft my own eye (SOMEHOW!) and I know that space it at a premium in the eye area. I was just wondering what is typical. With diffuser sheets that takes up more room too.
Post by Red Eye » Wed Jul 01, 2009 9:17 am
I've also ordered a sheet of red diffusion paper, too...
As soon as I got my helmet back, I'll cut it to size and apply it over the LEDs.
Hope the end effect will be as great as C.O.R.A.'s...
Galactifan
Re: Cylon Hyperdyne labs scanner with diffusion
Post by Galactifan » Sat Jul 04, 2009 2:24 am
C.O.R.A wrote:I took the Hyperdyne Labs scanner and my led holder but this time I pulled the led back a little and added two layers of defusion paper and then a piece of red gel. It now more looks like a bulb scanner. Here is a youtube clip of it in action.
Jim
Nice work!!!
Galactifan
It looks pretty good for an LED.
womo68
Post by womo68 » Tue Jul 21, 2009 2:24 pm
Looks great! Where did you get the holder? I need one 8)
Post by Skullbeast » Sun Apr 10, 2011 11:25 pm
ok now.... :huh: What is the best cylon eye scanner currently available :cylon: >Zeta :cylongold: > hyperdyne > or another :erk: I haven't heard of? I have a friend trying to build one as if we would do one at the studio, but i want it to be faithful also.
Post by Cylon-Knight » Mon Apr 11, 2011 12:21 am
Skullbeast wrote:ok now.... :huh: What is the best cylon eye scanner currently available :cylon: >Zeta :cylongold: > hyperdyne > or another :erk: I haven't heard of? I have a friend trying to build one as if we would do one at the studio, but i want it to be faithful also.
Neither is really "faithful" as the original scanners use light bulbs - not LEDs. Blubs had the inharent "fade" to them as power is given/taken away. LEDs are very harsh ON and OFF... any fade to them has to be engineered into the electrons that drive them to step power to/from them. The original bulbs were also very hot and dim and used much power... two big reasons that most Cylon builders have gone to LEDs - cooler, BRIGHTER and much less power needs.
I have a Zeta eye and will probably one day get a hyperdyne one to see firsthand if they see eye-to-eye (HaHa - funny me).
Our own member Retro1 sells a 10 LED version of the eye for budget builders... other than him, Zeta and Hyperdyne I've heard/seen no others "out there." If anyone else has POST!
