Just an update, the hand armor is ready for vac forming, and the next time I fire-up the vac former, I'll pull some parts in .060. Also, the forearm armor is ready for it's first test pull.
Every part I pull I have to test to make sure it will work as a vac pattern, so far so good. Once the part is test pulled, I'll trim it out, and then see if I can fit it together. If there is an issue wearing it, then adjustments are made, and then back to test pulling.
Jim
Arm molds ready for test pulls!
